Task monitor for an L8 processor
kpElec
Oct 2016
Minnesota
23
Hi all,
IÂ’m trying to monitor an L8 processor using Task Monitor. I realize the original Task Monitor isnÂ’t used for the L8 processor, so I attempted to use IE and Chrome to view the processor utilization. When I type in the IP address, the 1756-EN2T shows up rather than the L8 processor.
Can anyone tell me why that is, please?
Thank you.
It’s because you typed in the address of the EN2T.
The L8 has an onboard NIC and (should) have its own IP.
Ah, right. Unfortunately, the L8 is connected to the 192.168.1 network and I'm trying to reach it through remote desktop using the 192.168.100 network. That tells me that I need to connect the 192.168.1 network through a NAT and formulate the 1:1 translation. To bad there isn't a feature using a browser to drill in to reach the processor such as the original Task Monitor using Linx to drill down to the processor. I think that in the future, I will be using a 5069 series that has two different network ports and have a local and a remote subnet. Thanks.
Hello, I have trouble understanding the "Comms" part in the CPU usage pie chart showing in RSLogix Task Monitor Per the RSLogix Task Monitor...
896
Rslogix/Compaclogix system While monitoring a liquid transfer from a flow meter and using RSLogix on-line to watch what was happening, I noticed...
1,235
Is there a way to get the data about the CPU Usage into our HMI? I see that Rockwell can read the task scan time and the configuration time...
1,736
Logix5000 Task monitor will crash when I point it at anything. It loads symbols etc but then after it displays it all it crashes. Pointing it at...
2,574
Hi. I have a L85E CPU with FW 28.12. I can see the CPU in Linx but when I select it in the Logix Task Monitor v 3.4.1.0 I am not able to start...
6,233
