TCP / IP Communicatio with CompactLogix L30ER
jthyge
Feb 2020
Randers
Hello
Is there any way to communicate with a CompactLogix L30ER with plain TCP / IP.
Similar with the TCON in Siemens TIA Portal?
I need to communicate with at S7-1200 in TCP / IP. And have a working solution for the Siemens PLC.
Hello. Thanks for your answers.
Firejo->Im working on af school project, so cant buy hardware.
I am now trying to crack the "EtherNet/IP Socket Interface".. Not easy.
I have created at working socket, but in my "OpenConnection" MSG i get the error code 16#0005;Class or instance not supported.
I have checked the FW. Its version 32.011, so this should be fine.
The error code description does not help me much.
Pictures:
https://ibb.co/Fg4GHF7
https://ibb.co/fS9Z1Hf
Good people of PLCs.net, I am currently working with an HMI that is advantech 1250H, that communicates with a 1769 Compact logix and Currently...
90
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
380
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
261
Hi, We have an application that has a device that goes through a reboot (appears un-graceful) What then happens is the MVI module appears to hang...
95
I am very new to Modbus and the industry, so forgive me if I am missing something obvious. I have known Modbus register addresses coming from a...
286
