Phil Buchanan
Team viewer or LogMeIn is good for connecting to customer computers for the occasional service but for connecting to equipment on a permanent or semipermanent basis I would use hamachi or zero tier or neo router and you can connect to your plc just like you are on the local LAN because logically you are. For pc support on these solutions just use VNC or built in RDP.
so would you recommend using any of the above mentioned routers versus a solution such as E W O N or Tosibox?
No this simply means if you are on the LAN connecting to a machine on the LAN the traffic won't go out to the internet and come back it will route across a local path on the LAN. Its not a SDN like the titles I mentioned.
