Temp control
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello, I have heated acid tanks that have agitators in them that can not be turned-off unless the temp is below 90-degrees. The problem is, when the temp goes from 89-90+ it causes the agitator to turn on and off continually. Is there some way to create a dead-band (I think is the term I'm looking for) so that it doesn't continue to turn on and off? I have a SLC500 with an 5/03 processor. Thank you.
Use On and Off Timers controlling a B3 Bit, and use that to Start/Stop the Agitators. For example a 30 or 60 Second Timers, or whatever your process can handle.
Stu.....
We have a small plastic parts oven (SP at 210F). It used to have an old bimetal temperature regulator. We are upgrading it using two temperature...
1,533
Needing some help. I have a machine that was put in storage and has ended up in my lap. It had a 5/02 originally but the card was pulled and I...
1,415
I'm tasked with replacing a process's temperature controllers (which feature PID autotuning) with PLC control. Do any PLCs feature PID autotune or...
33
10,227
Hello I have DTC 1001 and DTC 2001 delta Temp control connected to together as one unit , and this unit connected to SS2 plc via Rs485 , My...
1,035
We are currently running 3 point temp control of a kiln and recently had a thermocouple failure which caused issues with our heat up cycle. In...
2,336
