Temp controller problem
harshad
Jul 2005
I have GE fanuc Versa max PLC.
But in Versamax plc have only Analog PID controller & my heater is a digital output. so how I can integrate with PID to digital output.
The basic technique is to "convert" the output of the PID loop to a 0-100% signal. Then use this to change the pre-set for a timer controlling your heater. 100% will be heater on continuously, 0% would be heater off continuously, and 50% would be on for 10 seconds, off for 10 seconds for example. Obviously you would need to select the time period as appropriate for your application.
We have found a bug in our AX9 temp controllers, after making one setting it disables the ability to use the RL2 output for a "High Temp Alarm"...
1,415
I am trying to use a Micro820 to communicate with a Solo SL4896VRE temperature controller. The Solo came from Automation Direct. physical...
2,745
I work on a plastic extruder that uses the following components: SLC 5/05 PLC Eurotherm T940 Process Supervisor -Eurotherm 2500 modules...
1,599
I am currently have a bit of an issue connecting to a Love 2600 temperature controller via RS485 full duplex with a Grid Connect NET485 Modbus RTU...
2,324
Hello, Does anyone know of a good non-contact temperature controller? Thanks, Dave
1,950
