Temp Level Sensor
ndzied1
Aug 2002
Chicago, Illinois
2,857
Hello,
I'm looking for a float style temp/level analog transmitter (0-10V analog) for a water tank. There are no chemicals in the water but the tank does get to 200DegF so that is a consideration. Tank is about 24" deep. I don't need to measure to the bottom but would like a decent range over the 24".
Don't need any switching outputs.
The tank exists and our existing sensor has failed. Looking for a replacement available pretty quickly so we can finish our project and ship the system.
Thanks. I will call them tomorrow. I was able to get a replacement from the original manufacturer but it’s longer than I want. Wish the temp was also 0-10 or 0-5 V but I do have a T/C signal conditioner so that could work.
Dear All, I am developing an application in our company lab for training purpose, My PLC contains 16 DI,12 DO , 4 AI and 2 AO. Please find the...
2,177
The objective: Reach about 10’ horizontally into a 1300F furnace, and pick up a 140lb rectangular container, then pull the container back out of...
1,874
Hi Everyone, We have Silo System which has temperature sensor and these sensor data will be communicating through RTU unit to the Dedicated PC...
617
We have a small plastic parts oven (SP at 210F). It used to have an old bimetal temperature regulator. We are upgrading it using two temperature...
1,535
We have a vertical Axis which was overheating while not moving. After further investigation I found that when the axis moves upward to a...
1,210
