temperature control with a process controller
rock
Aug 2003
35
Have a question that I hope someone can help with.
Have been looking into using a Omron Process Controller to possibly control a
I/p tye valve for hot water.
Could someone give me some insight as to whether it is possible to use one of the process controllers with a thermocouple or rtd sensor connected to it and control how much a valve opens to allow hot water to flow depeding upon how close to the desired set temperature is that you may need to heat something to.
Would apprecaite any help. Just learning about controlling valves this way.
Seems like it is a more efficient way of controlling a valve this way if the application is not large enough to justify using a plc.
You will find that most of those controllers have an automatic PID tuning function that generally works very well. Press the button and walk away.
beerchug
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
625
Hey everyone I'm trynna write a program to a WEST PRO16 temperature controller, but it just won't download the program i made using BlueControl...
754
I am at a loss... I have a pasteurizing system that i need to control product temperature with the speed of the product pump. I currently have a...
2,608
Hello PLC community, I'm looking for advice on a project that I'm going to do for the first time with a PLC (Siemens), the system is to do an...
1,578
I have PID temperature control which will connect to Beckhoff EL4004(0v-10v). How I can program it to let EL4004 to control the temperature?
2,638
