Temperature measurement
YCB
Feb 2008
Poland
17
Hello everybody,
I'm looking for temperature sensor to monitor temperature of metal surface. The best solution would be some programmable sensor with two digital outputs (i.e. warning and alarm).
I need something with digital outputs because currently in control system we don't use analog i/o and we will use this sensor only for monitoring.
Does anyone know such device, or anything similar?
Anothr solution would be to use a controller. With just 100% proportional band and no reset or derivative the output wil represent the temperature. Most have alarm relays.
Hello everybody,
what is the medium that you want to monitor, is it liquid or gas?
what installation you want,direct or indirect contact with the meduim?
cause some products are best for liquid and some are not....
We have a customer asking us to measure the temperature of a moving chrome covered roll that is near room temperature. We aren't allowed to paint...
2,428
I am needing to measure the water temperature in a hotwell and coldwell. I'm trying to find a transmitter with 4-20ma that I can submerge. Any...
2,034
Okay, I've been searching around, and not coming up with many good solutions. Problem: I need to run a temperature profile of a cable core...
24
13,252
I am in need of a means of measuring the temprature of the inlet and outlet of steam traps. What I am looking for would be like an RTD or TC with...
3,328
We are looking for a non-contact temperature measurement device to use in a oven where the parts are heated via infrared heaters. The customer...
3,903
