TConnolly
Due to the Seebeck effect, T/Cs generate their voltage over the entire length of the TC wire. You may find that losses aren't going to be an issue.
If the cable is copper and you use a type T TC then you can use one of the cable conductors and add a constantan conductor. You could actually make several TCs all sharing a single copper common.
Copper ------------+----------------+----
Constantan-------/ /
Constantan----------------------/
