rdrast
Okay, I've been searching around, and not coming up with many good solutions.
Problem: I need to run a temperature profile of a cable core, through a closed system. The overall length of the measurement is a minimum of 700 feet, optimum measurement would be up to 1800 feet. The temperature range is 70 to 450 F.
Possible solutions I've thought of:
1) Bury a TC in the core, and run a LOT of extension wire - concerned about losses in the fine gauge wire, and the difficulty of the physical hookup.
2) 'create' a fake TC Junction with a single wire, use that and the outer cable core as the conductors. Here, I'd have to profile my synthetic junction to calibrate it, but I still have attachment problems, loss problems, and the influence of temperature on non-standard conductors (Cu and something else).
3) Find some ultra-miniature, self-contained, temperature datalogger, that would log every second or so, and bury that in the cable. The problems here seem to be size, and the actual temperature limits of the dataloggers. I could perhaps get around the size (and case-melt) issues by cutting the electronics out of the case, and burying just them in the cable.
4) Put a specific defect in the cable, like a dissimilar metal crimp, and attempting to use some sort of TDR measurement...but I have no idea if that would be at all sensitive to temperature, or if my equipment would be sensitive enough to qualify it later.
In all cases, I can run an ambient temperature baseline test, before the at temperature test, to generate baseline losses and such.
Any thoughts? I'm still mostly looking at going with option 3, if I can find a suitable device. In this case, the device can be completely sacrificial, as long as I can read the data out one time.
Regards,
Regards,
