Test & measurement equipment
flyers
Sep 2006
Amk
295
Dear guys,
Sorry, this is not a PLC related question, but do hope if any of you guys come across these equipment. I'm looking for a test * measurement equipment for a production factory lab. This equipment must be able to measure the hollow object internal & external diameter. All these data will be send to a PC for historical data logging using either serial,USB or Ethernet. My location is Singapore.
Thank you.
What is max and min diameter outside
min and max dia inside
what is your accptible tolerance?
Where are you taking these measurements on the machine or at the QA station
Dan Bentler
Dan Bentler
The min diameter is 2", max dia. is 3.5" only.
Tolerance, not sure how precise are these equipment, no idea.
Measurement will be taken at the QA station in an air condition lab. Random test on the production.
Hi, I am using M221 reading from 3 different sensors (modbus rs485) sharing same bus (daisy chain). I am currently using READ_VAR (in total...
87
I am trying motor startup with pf525 drive by using wizard start over ethernet communication but during direction test it's showing control error...
189
See code at the bottom. Hi all. For the story, this is my first complete project using a Rockwell PLC, I've been mostly working with Unity Pro...
797
My question is regarding the number of Test outputs vs the number of inputs in a module. In the case of a 1734-IB8S card, there are 4 test...
1,199
Hi, I have to test a control logic that required to change the input temperature as the process variable from thermocouple transmitter on the...
625
