Test PID Code for SLC-500
rywins
Feb 2013
Philadelphia
29
How can I test some PID code I have written for a SLC-500 in RSLogix500, without having an actual processor to test on. I have used Emulate500 to date, but was having issues getting the PID block to function. I learned that, it will not run on Emulate500 (meaning, Emulate500 will not do any calcs, move CV, etc). Is there any other software or recommendations on how I can test my code, other than on a physical controller?
Thanks!!
Are you using a PID instruction, or did you construct a PID algorithm from ladder elements?
The reason I ask is that Emulate500 does not emulate the PID instruction, but one that it is straightforward to implement the PID algorithm using basic instructions that Emulate500 does emulate.
You have two problems. No PLC and no model to test it on. The good news is that the SLC/500 PID uses a relatively standard ISA PID with dependent gains and time constants in minutes. In other words it is easy to write PID in Excel or some other language to simulate how the PID works. The real problem is simulating the system to test it on.
I have wondered if people are willing to buy an Arduino or Raspberry PI if it had the ability to simulate temperature control and other systems. It would require a good quality analog input and analogue output. I think I would lean towards the Raspberry PI.
It amazes me tha the SLC500 simulator can simulate a PID when it is so easy to do.
Hi everyone, I am interested in learning about PID Loops. I have not used one in any of my programming yet but want to be ready should it come...
2,102
Hello, I've been tinkering with PIDs for a while now and have a pretty good understanding of all of the terms. I typically set my initial (first...
2,011
I need to make a PID loop to control a 4-20 mA signal to a recycle valve that controls a pressure. Is there a way to test the PID controller...
3,446
Hi, I am using M221 reading from 3 different sensors (modbus rs485) sharing same bus (daisy chain). I am currently using READ_VAR (in total...
88
I am trying motor startup with pf525 drive by using wizard start over ethernet communication but during direction test it's showing control error...
191
