Texas PLC Conversion
YoungWint
Dec 2012
East Midlands
77
I am looking at a TI445 (Texas Instruments)PLC which requires reverse engineering to operate on a Siemens Platform, or possibly an Allen Bradley.
Is anyone aware of a conversion package for either platform?
Also does anyone know if there is a way of viewing the source code on windows as the original package was DOS based.
I believe the source code is available and have assumed there in no need to upload from the PLC.
With thanks in anticiaption.
Can you post a link to a datasheet? I did a quick search and found nothing. Are you sure it is a Programmable Logic Controller and not a Power Line Control device? Even if what we call a PLC, very unlikely there would be any conversion program to another's PLC code. Structured Text is about the only language that can be copied directly between PLC's.
Siemens has a TI-to-S7 Converter.
It is included standard with STEP7.
Have never used it, so cannot say if it is good or not.
Btw, are you sure that it is a "TI445", not "TI545" ?
TI5xx is the version that can be converted to S7.
TI also had some CPUs that were rebadged Automation Direct PLCs. I remember vaguely that they were labeled TI4xx. Dont think they can be converted to S7.
edit: Post some photos of the PLCs in question.
Double check your part number I think you mean a 545 also. TI had a 400 series and it became the PLCs that Automation direct started to sell. You can still buy them and swap a 400 series TI for and Automation Direct 400 series and use the same I/O.
The TI545 was sold to Siemens and they in turn sold it to CTI who still make a replacement PLC.
As Jesper explained there is a converter to S7 and it does work better than most. Just have a strong understanding of your process and be ready for some testing.
Anyone know of a good place to take PLC classes or anyone looking to tutor a PLC novice in the Dallas, Tx area?
2,660
Upgrading an old TI PLC with a chassis PN 500-5840. has terminals on top and bottom but can't find a wiring diagram earlier. Help!! actually...
947
Texas Instruments PLC model 500 series; does any one knows were I can still purchase the software for uploading the program ? Ervin
2,778
I need help writing code that sends one real # out of a serial port (RS232)in form of an ASCII string. The processor is a Siemens (Texas...
2,108
HELP!!!! I'm looking for datasheet/spec sheet for a 555-1106 PLC. I need specifics on memory sizes. Thanks!
3,402
