Text Display TD17 (Siemens)
userxyz
May 2002
any
2,768
Hi All,
It's my first time I'm using a TD17. I worked with TP170B, OP3, OP7, OP15 and OP17 without a problem. But for the TD17 I have a little question.
The thing I need to do: There are 14 Tanks, each of them with a minimum sensor. I need to visualise minimum alarms.
When a tank comes to low then a bel will ring and it will be shown on the TD17 in Large + flashing.
To reset the alarm, the Escape button of the TD17 is used (key assignment, bit x.3. The the bel will stop ringing and the message has to stop flashing, but needs to be shown as log the tank is to low !!
Now: I worked this out, I made Event messages in protool and used DB60.DBW2 to use as controlword for the messages that needs to be shown in a flashing condition. That part works perfectly !
What doesn't work:
For the messages that have to be shown continue (after reset with the escape key) I made another event messages (aria pointers), this time on DB70.DBW2.
I've tested this all with a VAT table, and it seems that the flashing messages are shown correctle, but the messages that have to be shown continue (DB70.DBW2) won't work. Don't know what went wrong. Coul it be that I have to many variables in my Vat ?
Something must be wrong. :(
We use TD17's to visualise Emergency Stops. The problem I had, was that there were 6 emergency stops shown on the panel. Not one emergency stop...
4,439
In GT designer 3, the rig operator wants me to display a text string on the screen when a bit goes TRUE, and make it disappear when the bit goes...
1,922
Rockwell Software Studio 5000 View Designer v6.01: Is there a way to limit the number of digits of a REAL tag that get shown in a text display...
1,885
I have an old Beijier text display which has failed in the field. This is long obsolete. Can anyone suggest an alternative to interface to an...
2,107
Working in FTVS10 and was just curious as to other people’s preferences and perhaps some logical reasoning as to why you would use one over the...
1,983
