Text string with bunch of questions
ziyaddin2015
Nov 2019
USA
85
Hi All,
I have a problem with HMI where the tag string shows a bunch of question marks. I am not sure where to go from here?? I believe someone else had fixed a similar issue on the other line saying he updated UDT. Any suggestions will be greatly appreciated. Thanks
That appears to be a Rockwell FTView ME HMI, and it may mean that the tag associated with those "?" is longer in length that what the graphic is currently set up for. I.E. Tag is 20 characters long but HMI reference is only 17 characters long.
That means that the tag that the HMI is trying to display is not found in the PLC.
When this happens to me, either I mistyped the tag in the HMI display or changed the tag name or UDT structure in the PLC.
The asterisk on the end says the display is set to more characters than there is room for.
Do I need to download to HMI in the case where the tag was mistyped? I ll ckeck out UDT structure in PLC as well. Thank you all.
Hello, I am using studio 5000 pro and am trying to figure out the structured text. Here's my scenario: An operator scans a barcode, the barcode...
304
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
195
Long story short, I am creating a display to display an array of Strings from PLC [topic]VarStrA_RPHD.Desc[VarStrB] totally 100 strings...
1,418
Hi all, I have a customer that is asking for a recipe of 200 recipes to be sorted. I'm trying to do this by way of a bubble sort. Basically my...
18
3,544
So in Ignition I can make a Tag have a datatype String, or a datatype Text. I poked around in the docs and couldn't find an explanation for the...
2,084
