the protected cpu
MAHER
Jul 2007
CAIRO
82
HI all
i have a new project which i will use an old cpu has a type
-cpu 313 v1.0
-sm di 32 24 vdc
-sm do 32 , 24vdc 0.5A
i was uploading the old program from the software but when i was trying to download the new software this message was appeared for me ( the module /memory card cpu313 is password protected ) how can i delete this password or erase it?????
help me
i am going to wait the replying
best regards
MAHER
HI all
-cpu 313 v1.0
-sm di 32 24 vdc
help me
best regards
MAHER
Since it is an old 313 and has no MMC and you have a program and you don't care about what's already in there, just perform a "RESET" using the key switche.
EVERYTHING will be erased and gone so you have to start from scratch.
IN case it has a burned "EEPRPOM" it'll look like an PCMCIA card plugged into the slot of the CPU, remove and load your new program but DO NOT re-install the card as it will drive the CPU to a fault.
Hi
I was trying to download the new program to the cpu only after removing the MMC but i got the same message (the module / memory card cpu313 is password protected enter password )
so what is your openion ?
thanks alot
maher
no way to find out a solution for this trick
maher
The only thing I can come up with is wipe out the CPU and start from scratch.
If you wipe out the CPU and start fresh, there will be nothing left there that requires you to enter a password as all data and settings will go back to default.
sorry
can you explain the procedures for me by details????
also how can i be sure that the cpu hasn't data on it???
thanks for your attention
maher
sorry
maher
Memory Reset:
Put the CPU in STOP mode.
Use the key switch.
Once in STOP Mode,
Hold in MRES position for 3 seconds,
release and
within 3 seconds MAX (must be done prior to 3 seconds max elapsed time from release)
turn and hold the switch to MRES for at least 3 seconds.
If you perform the above functions successfully, you will Reset the CPU and memory and place the cPU to a default (basic, as shipped) state.
Re-load your hardware configuration,program/blocks, etc and you should be good to go.
Hi All, I was wondering if anyone could help with a Hitachi EH-150 CPU which is password protected. The company who placed the password is no...
1,666
Anyone knows how to remove the pasword protection of Siemens S7/300 CPU without having the password? if possible, will there be any data loss...
12,612
Dear Friends, can you help me to extract the ladder diagram from protected omron cpu unit model (CQM2H), i know that their are some way to open...
1,900
Hello all, I'm trying to use the Logix Designer SDK to upload and download a single ACD to many controllers. I got this to work fine copying...
86
Pls anyone help me out to crack the Codesys lib File pls share password for the if any application to crack or any master key for Codesys library...
806
