The speed of a Devicenet Network
Rob S.
Sep 2008
Maryland
739
Good Evening ,
I have a customer that has a clutch that energizes about every 1/2 second
or a little less. Since they purchased the machine about 7 years ago they have had random problems with this clutch circuit not stopping or stopping premature. It is on a DeviceNet network. This network has about 70 Inputs and Outputs on it. What is the speed of a DeviceNet network , and do you think that this could be related to the problem ?
Thanks in advance,
Since they have had the problem consistently since the machine was installed, I would rule out a malfunction, and agree with you it might be a configuration/network issue.
It is not the number of I/O points on the network that is relevant to the equation. What we need to know is the number of "devices", aka "nodes" on the network, since devices can deliver many I/O points.
We will also need to know the network speed (Baud Rate).
Do you have a devicenet configuration file for this network (eg. *****.dnt) ?
Don't know if you'll be able to post it on here, but you should be able to send it to me by PM or email...
It's impossible to determine the data exchange speed without measuring it with an analyzer, but you can estimate.
The default "interscan delay" is 10 milliseconds, and as a rule of thumb I add 2 ms per device to get a rough estimate.
Sigh, DeviceNet noob... I have a 1756-L55, with a DeviceNet module, and 10 PF700 all commanded with DeviceNet. One of the PF700's blew up...
150
Hi - I have done some searching and answered a lot of my questions but..... I have a Powerflex 40 drive communicating to an 1769-L35 over...
2,404
Hello all, I don't have much experience using devicenet and was wondering how the I/O update speed compares to hard wired digital I/O. My...
2,808
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
125
Hello, I am trying to setup on plc so If I enter 60 jph (job per hour) it will send the vfd hertz based on what jph is entered by...
176
