Thermistor question-allen bradley LDC motor
anav
Jun 2017
Rochester
Hi All,
I am trying to interface the PTC thermistor output from the Allen Bradley motor to temperature controller-CN245 from Omega. The relay output of which I would connect to the Ultra3K drive. I used the PTC input for the controller. But the ouput temp always reads negative values.
Hence my question is: what is analog signal from the thermistor? I did read in this forum "The servomotors don't have a physical temperature sensor so instead the drive has a model of the cooling characteristics of each specific motor and measures the current and duty cycle of the motor. It's actually a "modeled over temperature trip".The drive also uses this information to calculate a Motor Temperature parameter.” not sure if they user is talking abt the same motor. I would like to record the temperature using the PLC and keep it for future reference. Hence I do need to read the motor temp.
Any pointers is appreciated...
I have a motor with 2 thermistors. One pair reads 1.0 ohm and the other 247 ohms Does this indicate one of them is bad? Which one? Also these...
1,669
I have TM221CE40R controller along with TM3TI8 temperature module. Temperature sensor we are using is Thermistor with below part no. AXIO...
1,989
Can someone explain how a Powerflex 525 drive interprets the PTC Thermistor signal from a motor winding? How does one know what the levels are or...
4,042
Thermistors........Can someone explain how they work and how to control the speed of a vfd with them? I am not familiar with thermistors, but a...
31
5,993
Dear all, I am driving 11kW induction motor from Schneider Altivar ATV28 VFD. My 11 kW motor is equipped with thermistor but i am unable to...
3,396
