TI 545 / ControlLogix 5563 comms
josh_d
Jan 2011
Vic
20
Good morning from Aus,
Currently installing a controllogix 5563 into a plant that requires comms to and from a TI 545 (or 555).
Wondering if anyone has had any success with soft comms between the two. Or as I'm thinking... hard comms may be required.
Any help/suggestions greatly appreciated.
I have had great success with the Control Technology 2572-A module. It creates a set of pre-defined ControlLogix array tags that you can associate with memory areas in the TI controller, and then read and write using MSG instructions in the ControlLogix.
http://www.controltechnology.com/products/2572-a/
If you need deterministic or very fast cyclic data between the control systems, I'd choose a Profibus DP module for each one. It's a little more complex to set up but the data transfer is faster.
Hi Josh,
Removed my response after I read Ken's reply..
Just out of Interest you wouldn't happen to be working just of Geelong at a Cement Plant would you ?
The name was a bit of giveaway. Is Chris back yet ?
yeah subtle isnt it...
no hes not, middle of feb
theyre on shutdown at the moment so its fairly hectic and without their control systems engineer to sort things out im not sure the project managers are realising theres no one to do their coding...
haha! Thanks. Might see you there sometime soon then..
Still can't believe of all the programmers in the world you reply, whats the chances..!
Hope all else is well and you're keeping busy. All the best for the new year.
Thanks for the info Ken, luckily enough the ethernet card I had in our test rig is a 2572-A. All up and running well. Didnt take too long either.
I am working with a Siemens 545 PLC and the MODNIM Modbus module and I am trying to figure out if the module is a Master or Slave. It does Modbus...
1,820
What software and cable are used to program a Simatic 545? We have 3 on winders and need to make a small program change for a new product line...
1,833
Any old TI545 boys or girls reading this? Something I never figured out. We have one RS232 serial connection between our PC and the 545 Port 1...
1,340
Good day... Had a "boot" fault on display. Unplugged pump and when I plugged it back into power, the display is blank. I know that the unit...
2,028
Hello Long time lurker. I am flailing around trying to figure out how to implement MODBUS TCP on a W2000 IPC that controls one of my company's...
5,906
