TI 545 Timers
dog
Aug 2009
AZ
Iv'e run across a TI545 whose timers count down from preset to zero in roughly one half the time (15 sec preset only takes 8 sec to zero). Don't they derive their timing from the RTC independent from scan? (scan is set to variable)Any help would be appreciated. Thanks
Some timers require scan rate. You may not be reading this correctly or it may be called twice and decrementing x 2.
I am working with a Siemens 545 PLC and the MODNIM Modbus module and I am trying to figure out if the module is a Master or Slave. It does Modbus...
1,814
What software and cable are used to program a Simatic 545? We have 3 on winders and need to make a small program change for a new product line...
1,825
Any old TI545 boys or girls reading this? Something I never figured out. We have one RS232 serial connection between our PC and the 545 Port 1...
1,334
Good day... Had a "boot" fault on display. Unplugged pump and when I plugged it back into power, the display is blank. I know that the unit...
2,023
Hello Long time lurker. I am flailing around trying to figure out how to implement MODBUS TCP on a W2000 IPC that controls one of my company's...
5,894
