TI 545 to op177b help
Orphe
Jan 2011
Houston
Hello all
To be honest I’m fairly new to the PLC world and even newer to HMIs But here is my dilemma at the moment.
I need to connect a TI 545 plc to an op177b HMI. I must build the HMI program using winccflex 2008. I’m not sure what kind of cable interface I need to use or if there are any special settings I need to set up for the PLC.
Any type of interface can be used (I must build the cable). Ethernet is also an option. Any suggestions or help would be greatly appreciated.
Well, if you have the DP mono model, you'll have to use Serial, The port on the PLC is pretty bog standard, I don't have the pinout in front of me but it isn't anything fancy. I think it defaults to 19200 8n1 if the dip switches haven't been changed.
If you have the PN/DP color model HMI, you can use ethernet I think.
I am working with a Siemens 545 PLC and the MODNIM Modbus module and I am trying to figure out if the module is a Master or Slave. It does Modbus...
1,812
What software and cable are used to program a Simatic 545? We have 3 on winders and need to make a small program change for a new product line...
1,824
Any old TI545 boys or girls reading this? Something I never figured out. We have one RS232 serial connection between our PC and the 545 Port 1...
1,333
Good day... Had a "boot" fault on display. Unplugged pump and when I plugged it back into power, the display is blank. I know that the unit...
2,020
Hello Long time lurker. I am flailing around trying to figure out how to implement MODBUS TCP on a W2000 IPC that controls one of my company's...
5,888
