TIA - Function Call,
In your FB6, what happens when #Run is false and the block is called?
Your code is nice and compact so it will not make any real difference in this case but nice to be cognisant of it.
This is not the whole code is it? I recall you saying the block will execute for more than one scan and in that case there will be four conditions, not necessarily ordered this way:
Rising Edge of Run,
Run := TRUE,
Falling Edge of Run,
Run := False;
So this is basically how I approach two areas that I saw in your code.
IF conditions, I do my best to keep "uniform" (can't think of a better term). For example:
IF COLOR = White THEN
do this stuff;
ELSIF COLOR = BLUE THEN
// here I may prepare condition for another IF or CASE
ENGINE_TROUBLE := TRUE; // blue smoke or something
ELSE
do something different;
END_IF;
What I avoid is mixing two case or if statments:
IF COLOR = WHITE THEN
do this;
ELSIF ENGINE_STATUS = TROUBLE THEN
shut the engine off;
END_IF;
The above is difficult to follow by someone who is not intimately familiar with the code, or me after months or years.
For block enable I pretty much follow a template and add or remove from it as needed but again on requirement is to have my IF condition very easy to follow, a quick scan of the first section tells you when the block is enabled.
Then I follow Siemens and I think PLCOpen recommendation for status and error reporting and that I satisfy the requirement that goes with Enable which is to BLOCK_ENABLED, or ACTIVE or anything you want to call it.
Note: I made some quick changes in the code while posting and hopefully didn't screw it up, should still make the point.
Code:
FUNCTION_BLOCK "FB_Enable"
{ S7_Optimized_Access := 'TRUE' }
VERSION : 0.1
VAR_INPUT
  Enable : Bool;
END_VAR
 VAR_OUTPUT
  ob_IS_Enabled : Bool;
   ob_IS_Error : Bool;
  Status : Word;
END_VAR
VAR_IN_OUT
END_VAR
VAR
  Enable_Edge : Bool;
END_VAR
VAR_TEMP
  tmpb_Init : Bool;
  tmpb_IS_Block_Enabled : Bool;
  tmpw_STATUS : Word;
  tmpb_IS_Error : Bool;
END_VAR
VAR CONSTANT
  //enable
  BLOCK_ENABLED : Word := 16#7003;   // block enabled
  BLOCK_DISABLED : Word := 16#7004;   // block disabled
  // status
  NO_ERROR : Word := 16#0000;   // No errors
  AWATING_FOR_REQUEST : Word := 16#0001;  // got positions and wating for request to add more or load more
  NO_CURRENT_JOBS : Word := 16#7000;   // Initial value= IDLE
  NO_POS_PENDING : Word := 16#8201; // no positions to process
  INVALID_COUNTER_VALUE : Word := 16#8202;   // counter value is invalid
  INVALID_TARGET_POS : Word := 16#8203; // 1<= target position<=maximum counter value<=2147483647
  INVALID_MAX_COUNTER_VAL : Word := 16#8204; // maximum counter value has to be greater than zero
END_VAR
BEGIN
    //FUNCTION: Enable
    //Enables and disables the block
    IF NOT #Enable AND #Enable_Edge THEN // falling edge of enable
        #tmpb_Init := TRUE; // reset the tags on the way out which is done at the bottom.
    ELSIF NOT #Enable THEN
         // exit block, return**nothing to do**
        #ob_IS_Enabled := FALSE:
         #Status := #BLOCK_DISABLED;
        RETURN;
    ELSIF #Enable AND NOT #Enable_Edge THEN //rising edge of enable
        // intitialize variables
        #tmpb_Init := TRUE;
    ELSE
        #ob_IS_Enabled := #tmpb_IS_Block_Enabled := TRUE;
        //block Status
        #tmpw_STATUS := #NO_ERROR; // idle
    END_IF;
    #Enable_Edge := #Enable;
    //beginning of block execution
    IF #tmpb_IS_Block_Enabled THEN
        // block code goes here
         // Update outputs
        // ***********output tags here*******
        // output status
        #ob_IS_Error := #tmpb_IS_Error;
        #Status := #tmpw_STATUS;
    END_IF; // end of enable
    //Reset variables
        // Initialize some variables
    END_IF;
END_FUNCTION_BLOCK
I forgot to put in your #Finished bit but the way you have it is good. Rising edge of #Finished resets the tag that is connected to #Rum and beyond that the only output from the block is its disabled status.
I created this FC and it compiles, but when I use it in my MAIN OB1, it appears to have two outputs. See pictures. What am I doing wrong here...
1,493
Hi Guys, A quick one please. How do I call in a Function in TIA and Simatic Manager? In AB, usually, JSR is created in Main Routine but for...
17
2,377
Im trying to create a level indicator for water Tank i have used the ADD function while the pump is on and level increasing everything works...
33
1,103
Can someone help me with this? I'm no good at SCL - virtually everything I've done so far has been ladder logic. The return value from the...
1,117
Hallo, I have Tia Portal V16 and I'm upgrading an older machine. That machine has a component running on rs232. The machine has still the old...
967
