TIA Portal Question
Jul 2007
Kiruna
600
Hi Guys,
Its been a long time since I've been playing with Siemens. (S7 V5.5 & Wincc Scada V7.0)
I have a project where the customer wants TIA Portal Step 7 V14 with WinCC Flex.
They want the HMI Panel based and not PC based. My question is whats the version to select? WinCC Advanced or Comfort? I need to get my old WinCC 7.0 project into a panel system which I guess means starting from scratch?
WinCC Comfort is for HMI Panels, and WinCC Advanced is for PC-based HMI. As a side note, WinCC Professional is the PC-Based HMI/SCADA equivalent of WinCC V7.x.
If you get WinCC Professional, you can develop for Professional, Advanced and Comfort applications. If you get WinCC Advanced, you can program for Advanced and Comfort applications. If you get Comfort, you can only program for Comfort applications.
It is possible to convert WinCC V7.0 applications, but you need to do a two-step upgrade: WinCC 7.0 -> WinCC 7.2 (or higher) -> WinCC Professional V14.
Hi Guys When using TIA Portal (v16 & V17) does the Upload from device (Software & Hardware) button upload all Parameters from any Inverters...
539
Hi Guys In a TIA Portal (v16 and v17) project where there are numerous Siemens G120 Inverter drives in the IO tree all being controlled via...
1,030
Hi all I have a project on the go and would like to send data from a Siemens 1500 to a Siemens 1200 What is the best function to use ,would it be...
4,497
I just found a piece of code using an operator "+=" IF tag1 AND tag2 THEN tag3 += tag4; tag5 := tag5 + tag6; END_IF; I don't...
4,861
Hi, Ok bear with me, I have an Array of Real in a DB ranging from 0 to 10. In ladder I want when count pulse = 100 move count into Array 0...
2,094
