TIA Portal Scaling analog output
bgeary
Jul 2008
Lincoln
Hi Guys, I just want to scale an analog output to 0-10V from an Integer value in the PLC (S7-1500) using Portal version 13. I assume it hinges around NORM X and SCALE X but a simple example of description would be great.:sleep:
Just for your info, Scale and unscale work only for the analog inputs and outputs of your IO. norm_X and scale_x are used in combination to be more flexible, and can be used to scale anything: analog IO, degrees C to F, mi to km, whatever. Norm_x normalizes the numbers, which means it takes the source and converts it to a 0.0 to 1.0 scale. Scale_X takes the 0.0 to 1.0 scale, and converts it to the engineering units you need.
The scale and unscale blocks work for what you are trying to do, I just wanted to answer your original question of what norm_x and scale_x are for.
Good point. The calculate block is great if you know the equation.
The Norm_X/Scale_X combo is good for when all you know is the two ranges you are trying to scale between, and don't want to worry about the math. It does require a linear relationship, however.
Hi, Didn't found an answer to this particular problem. As everyone probably knows if you use windows scaling of display crazy things happen to...
1,655
Dear all Iam using three load cells connected in parallel to calibrate the weight of a product but in don't have a weighting module in my...
3,500
Hi All I'm from an Allen-Bradley background and i'm using an S7-300 on a project. With scaling a channel in AB I had a Scaling Block setup which...
3,517
Hi Guys, I just want to scale an analog input (current ) from 4-20mA to an Integer value (0-100) in the PLC (S7-1500) also (300) using tia Portal...
18
18,344
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
40
