TIA SCL Monitoring Loops Function
Big_Robo
Nov 2016
England
81
Hi all,
I hope everyone is well, I am in need of something so simple, I have made a small program in SCL and want to monitor some loops in simulation mode but for the life of me I cant find it any option menus.
Thank You
Can you explain what it is that you want ?
When you simulate, the program runs as it would in a real PLC. An SCL loop will run as in the real PLC.
Do you mean you want to add breakpoints ? If so, search for "breakpoint" in the online help.
thank you for the response.
I have made a while command and when I simulate the message is gives me where is normally states (True / False) is "The monitoring of loops is deactivated by default)
in the drop down it then says "activate the monitoring of loops using the shortcut menu via the command *monitor - monitoring of loops*
I am used to ladder so this is new to me.
A side note; breakpoints work with s7-1500 not s7-1200; and not that well either. I have found it much more practical and time efficient to develop structured text code on other platforms, specifically CodeSys based, and port it back to TIA. Not necessarily the entire block but any tricky code that requires monitoring, stepping into or breakpoints. TIA is a nightmare for debugging.
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
335
Hi all, I'm currently trying to convert code written in STL for a S7-300 to SCL for an S7-1200. I'm getting stuck trying to address inputs in...
2,662
Hello, In step7 I would be able to access FB has been created by SCL and after assigning an associated instance DB i can monitor to debug the...
2,322
I have a ramp function which is using Time data type for calculation , I have converted the time to DINT and divided these values and saved in a...
5,351
I just found a piece of code using an operator "+=" IF tag1 AND tag2 THEN tag3 += tag4; tag5 := tag5 + tag6; END_IF; I don't...
4,832
