TIA V12 WinCC Adv. Comfort panel Faceplate text
TurpoUrpo
May 2008
Switzerland
1,571
Hello,
Does anyone know of a method to make text in faceplate configurable in interface of faceplate? I tried to use wstring tag and that tag in text field, but it wont let me use constant in interface for it.
What I want is to display Tag of item (eg. F0001-XXZZZP1) in a faceplate, I would want to configure said tag in interface of that faceplate.
I'd like to do exactly the same thing. I have a instance DB that i have added a String Data Type on my plan was to call an FB with the instance DB and enter the name in the PLC. Then in WinCC, tag it to a text value in the face plate. The problem with this idea is i don't know how to enter the value at the actual input of the block. I've tried 'Motor Name', "Motor Name", STRING#'MotorName" but it all comes back illegal parameter. Can anyone help?
Regards
Shamus
I got this sorted by doing the following: -
In TIA in the Instance DB for my standard motor block (or any DB will do) I added an input declaration called {TagName} with a Data Type {String[n]} (n = number of characters you want in your string)
On my faceplate in WinCC V12 I added a Property under the Status section and called it {TagName} and data type {WString}. I then added an I/O field to my faceplate. Under "General" I set it up the field as a string of the length {n}, input/output and linked it to my status tag.
Once you are out of the Edit Faceplate section i added the Data Block tag to the interface list for the relevant face plate.
Now when my face plate pops up i just press on the string position and fill it in with the name of the item.
Ignore the {}
Hope this helps
Shamus
hello all, I have a project in Wincc V15 and I need to copy some screens from V15 to V12 TIA. How do I it. I cant copy paste as there are...
1,937
I want to prepare a PC for a client that has TIA Portal WinCC V12 professional RT. I dont have the installation DVD that came with Siemens as it...
2,984
Hi, i have a demo version of Tia v12 sp1 and trial version wincc professional sp0. I cant install wincc, because it is not the same version as...
8,339
Hi guys. Sorry. I can help me please, i no dont the program of a furnace, i do download en simatic manager, but so export a tia portal 13 i have...
1,839
Hello, I have a 1214 DC/DC/DC PLC with SW created by TIA V12 SP1. Project in laptop and SW in PLC are different - it means that some functions are...
2,179
