Timer Display on Panelview 300 micro
Salazard
Apr 2012
Vancouver
28
Need help a value to display properly on a PanelView 300. I can get it to display but counting in minutes decresing from preset value of TON ans I need XX.XX Hour display. And i can also input new set value thru panelview. any sugestions?
Please define which PLC - presumably an Allen Bradley type, the time base (if not ControlLogix). In the XX.XX display I take it the XX to the left represent hours. Do the XX to the right represent fractions of an hour or minutes?
When entering a preset for this timer would the operator enter hours only or hours and minutes? In what format?
When the oprator change the preset time on panelview 300 micro it should be minutes. Enter time = XXXX minutes.
Dose the right side of XX.XX represent minutes or fractions of an hour?
What is the time base of the timer in the PLC?
Am I right that you wish to display the timer remaining? (The timer's accumulator would hold the time elapsed.)
The answers will require changing the PLC program to perform the mathematical operations.
I will post a picture tomorrow. I did not get a chance to reply because I'm in the field the most of the day.
Yes it is an oven project i will use the panelview 300 micro to adjust the timer to baking. But the project has temperature controller. The out relay of temp controller goes to input of our micrologix. And thru program we manipulate the output that will go to SSR to turn on Heater.
Need Help
I attached a pic for my code.
Still I code figure it out how to make a display in panelview XX:XX hours:min from my timer.
Does any one know how to get your timer accum. value to display properly on a PanelView 300?? I can get it to display and even scale it, but...
4,558
Hello I'm still fairly new at PLC work, as my job requires much more than just PLC code, so I cant devote all my time to it, so please bear with...
1,641
Needing a panel mount style timer that would interface with a large numerical display. Tankline with 20000 + gallon dip tanks. Operators lower...
1,920
Can someone tell me how to display a timer value when creating a screen in Factorytalk View ME?
4,132
I have a TON timer (60 sec) I want to display the timer on the panel view, but when I set the tag, there is no data type for time... How can I...
2,570
