Timer formatting in RS5K
DoMore has the ability to format strings, and I can show timer acc as xx:xx once I move the value to a string.
Is this possible in RS5K V24.11 ?
I don't think you can directly change what the timer is displayed as, but you can possibly make an AOI which encapsulates a timer, and has a visible string output string parameter which you change based on your timer countdown.
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
97
Hi all, I have a simple question that I have overcomplicated and gotten stuck on. I have a variable, we can call it "light" that I need to stay...
329
Question to anyone with ideas about my thoughts on upgrading a very vintage timer, which is being used to switch between 2 5hp domestic water...
443
why my timer only executes once here? After first time i use it, ET stays at 0ms all the time. It is in FB
320
Good morning guys, I'm searching for a Timer relay which accomplishes the "flasher" condition in the photo attached, however, I need the ability...
560
