Timers in RSLogix 5000
dskplc
Aug 2013
New Zealand
119
Hello, I am trying to have 1 timer turn on a horn 4 times for a total of 120 sec. Is it possible to split a TON up into 4 times or do I split this up among 4 timers (TON), 30 sec each? Thank you for your help.
So you are turning it on 4 times, then would I be correct in saying that there would be a duration that it would be off between each ON duration?
There would be many ways to skin this cat. One way I'll throw out would be to use one timer and LIM instructions (using the timers ACC value) to define windows for the output to be on. So you could say that between 0 and 30 seconds the horn would be on, then 35 to 65 it would be on again. That would leave it off for 5 seconds in between. Adjust the windows and total time in the timer as necessary.
Just use a series of comparators and trigger the horn when the accumulator (.acc) equals your required time intervals...
Regards,
Rob
Do you mean -
ON - OFF - ON - OFF - ON - OFF - ON
with 120 seconds from the start of the first ON to the end of the last one?
You could use one 120 second timer then a single rung with 4 parallel branches. The first branch would have a LES than compare. The middle two would have LIM instructions. The last one would have a GRT instruction. Then in-line with the output would be a XIC of the Timer TT bit. Finaly the horn output.
Another way would be to use 7 timers, one for each segment. Then a rung, again with 4 parallel branches, each with a XIC contact of the 4 ON timer's TT contacts then on to the output.
It's up to you and how easily the program is understood by those who come after.
Hi
You could use 4 times or you could use a lim or grt and leq instruction and use the .acc
Of your timer to compare fixed values to
Both will work
Donnchadh
Thank you for the great idea. Here is a snippet of what I think you meant for 1 on / off. I need to turn on a tone and light for x seconds, turn it off for x seconds with this on/off occurring 4 times. It doesn't seem hard but I am not getting the light and tone to turn off during the off time.
I haven't used used timers and STL together, so thought I'd try them on my next project! I have the following code example: So basically I was...
3,140
Hello all, I have not used many timers in logix and was wondering what is the best method to do the following? I would like to start an agitator...
2,644
I have a merge program that a co-worker was working on before he quite recently. In the past month the merge logic grew from 17 rungs to now 49. I...
2,750
Hi Guys, Is there a way to reuse TON timers in RsLogix 5000? I used TON, then after it's .DN, then I RES it. Later on, I reuse the same timer...
7,126
Hi mates! I've got a very easy question here for you.... I need two clock pulse signals as the following scheme shows: |----|----|----|...
5,641
