Timers
The timer timing bit is true when the timer is timing. What we used to call OXO.
The timer enabled bit is true when the timer is enabled or OXX
And of course the timer done bit is OOX.
Hope this helps.
I recently did a program conversion from logix 500 to studio 5000 and when machine runs it depends on two ton instructions to keep the machine in...
17
408
Hi, I'm quite new to Rockwell PLC and currently trying to implement the following if Sw1 then for i:=1 to 20 by 1 do xEnable := 1...
391
I'm writing some alterations to an FPWin program and need to see the running value of timers so I can set them correctly. It's my first time with...
142
Hi everyone I am using Winproladder software for programming FATEK FBs PLCs and in programming, we often use Timers for activation of the...
612
Hi all, I have what is likely not a complex issue, but I am working in Automation Studio and want an accumulating/retentive timer when a...
17
1,940
