TimeSelector Codesys
boneless
Feb 2008
OKC
1,628
Hi all,
Running into a little issue I don't understand.
I have a historical trend in CodeSYS (running on an R-PI). It works pretty good as long as I am showing everything.
When I use the TimeSelector to select a time frame, I am getting weird results. Attached pictures will explain it better than I can in words.
Also, when I add a time to the selector (offline), for example 12h and hit enter, it will change my input to 6h. When I enter 6h, it changes it to 0h. Anybody got any idea?
What happens if you select the same time period (6/26 to 6/30) as for the SS1.jpg "Everything" picture?
For the SS2 - SS4 pictures, it appears that no data had been recorded at that time for day 7/1 and later.
That is it for me, out of here.
lines are drawn between 2 datapoints, so if no point the line will be horizontal.
check if datapoint stamps are correct , the data are taken every sample period.
Thanks all, I will have to check it out.
It is just weird to me it works fine if I only use the scroll thingy on the bottom, I can zoom and move. Just thinking the time selector should (in my head) set the width of my zoom.
it is an extra utility, however not perfect, i try to stay within iec61131, making my own graphics to be able to use them anywhere
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
298
Hello, I have a requirement to manage the text alignment dynamically. So, for example: 1. English Texts should be displayed from Left in...
90
Hello, I am new to Codesys, and am trying to learn about it for a project we're developing. I've got a couple questions, but first a little...
162
Hi everyone, as this is my first experience with Rockwell Software i would like to know what's the best way to make Enumerations?
513
I am trying to get Codesys to work with a couple of Moxa ioLogik E1200 series DIO devices (E1210 and E1211). I am able to write to the E1211 DOs...
178
