TIsoft DCU connection issues
LDK1989
Apr 2019
Wrexham
Hello all. I have got some Siemens TI305 PLC's with a 330 CPU. I am attempting to back up the software on them, connecting via D3-232-DCU with a RS232 connection to my PG. I have attempted to use TI Soft 2, V2.01 and V1.01 for series 305 and the Direct soft 6 software also and have so far been unsuccessful. The TI Soft is set up on a windows 2000 and the direct soft on a window 10 machine.
I have tried multiple set ups of the dip switches on the DCU and altered the baud rates on my PG's serial port on Comm1 also which has not worked. I've tried multiple different addresses to no avail also.
I'm not too savvy with the TI equipment so if anyone is your assistance would be greatly appreciated. Thanks.
My first thought was Siemens, Step 7 . . .
Probably not.
Question : Please If someone knows what software can I use to program a Siemens TI 305 PLC,
Answer > Try www.automationdirect.com for part #PC-PGM-305. Depending on which CPU you have, you may also need an RS232 adapter Simatic PPX:305-03DM, or Automation Direct D3-232-DCU. Rather than buy one of these, you might be better off replacing the CPU card with one having an RS232 port built in.
https://control.com/thread/975619623#975619623
(I know nothing of the TI 305 PLC . .)
(But Google seems to be able to find anything.)
Poet.
I have already got the D3-232-DCU which is what I am trying to connect with as per my original post, and cant replace the CPU until I have backed up the software.
I have been in contact with Automation directs UK based distributor Lamonde however they have not been able to come up with a solution for me.
As per the original thread post, I have all the hardware and the software packages, and have tried a few different things but just cant connect online. and have exhausted what I know on them.
I have done this upload many times. Is the CPU light on and also the RUN?
Make sure you have the correct RS232 cable between the DCU and computer.
As an interesting note: I had one case where I used the handheld programmer with a tape recorder to upload a 330 CPU - it would just not communicate, possibly due to a failure on the CPU itself. Usually I only needed the handheld programmer with older TI315 CPUs. In another case, I had to change the backplane.. but in that case, the CPU LED was dimmed, and the CPU would not go to RUN.
Hi. I have 2 files where I would like to see the ladder logic differences (similar to the Rockwell compare function). I am using TISoft Siemens...
1,268
Any old TI545 boys or girls reading this? Something I never figured out. We have one RS232 serial connection between our PC and the 545 Port 1...
1,333
Hi, Just looking for a quick pointer. I want to upload an old program out of a Texas 305 PLC. The program was last downloaded in the 90s so...
2,035
I have a TI 505 Program .V5P sent to me with no comments. I was then sent the .CMT file and I am wondering how to have the program update with...
1,398
Evening all. Looking for a bit of advice from some of the "old" hands used to working with Tisoft. I've got Tisoft v7.1 installed on an older...
2,293
