TMR & CTR Instruction in TI
mtariq_amin
Nov 2007
Jeddah
Dear All.
I am upgrading 25 year old TI plc to Step7.
The TI PLC is as follows:
5TI Expander
Model: 5TI-5500
Supply Volt: 102-132 VAC 47-63 HZ
Serial # : 15EX8510000491
Full load current: 0.75 A
5TI Sequencer
Model : 5TI-1031-1
Supply Volt : 102-132 VAC 47-63 HZ
Serial # : 81030077
Full load current : 0.75 A
I have the hard copy of TI Program.
I am facing Difficulty in understanding TMR & CTR in TI Program.
The TMR istruction is as follows:
The CTR instruction is as follows:
Kindly help me in finding out, how this timer and counter instruction is working
Which one is on-delay or off-delay timer??
Which one is up or down counter??
Your help regarding this matter will be highly appreciated.
Regards,
Tariq
The counters you display are up count only. An up/down counter is a UCD block. See examples below are for 5TI only!
Technicaly there are only on-delay timers in a 5TI. An off-delay is done by using the same NC contact in both inputs to the TMR block. I think the 5TI time in 0.1 seconds, TMR3=5 seconds.
Outputs turn on when preset P is reached in all cases. The UDC output also turns on when the dynamic count =0 when counting down. Additional contacts/rungs are needed to inhibit this. Such as X3 to allow/disallow in another rung. A little confusing at times.
I hope this helps. I had to review one of my 25+ year old manuals.
I 'm trying to convert a TI program to Step 7; i'm looking for a manual or someone who can explain me some simple ti istructions (overall CTR...
4,238
This is a Tangent from jefferypb’s thread about Anti-Tie-Down, or is it an Anti-Repeat? Regardless of what kind of mechanism jefferypb is really...
4,460
Does anyone have experience using these things? Can't get it to work for the life of me. I've used the Schneider cable to set the IP and I can...
2,301
Hello everyone, So I am currently trying to write some logic to a program that was not written by me. I am using a Mitsubishi PLC (QO6UDV) and...
1,411
I had to delay an output for 3 seconds so I added a TMR in the rung right before the output using 3 unused words from the %P register like I found...
1,680
