to use single display(output) for multiple inputs
tajammal
Oct 2010
Lahore
i want to display 08 analogue inputs (4-20ma) on a single display attached to one analogue output. each input value to be displayed after 5sec. the plc is siemens s7-300. i have used FC102(analogue scalling function , built in library) to scale inputs as per scaling requirements. what to do next?
Dear tajamal,
Move the analog value to data block and also write flashing logic or ring light logic then move db value with flashing logic to memory word, use this memory word for analog output.
regards,
This probably just falls under personal preference, but when using RS-Logix 5 what is the advantage or situation when it is better to split...
1,830
I'm looking for how others do it. I need to start a 1 phase motor. I have always used a regular 3 phase Motor Protected Circuit Breaker and looped...
209
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
102
I am converting a SLC 500 to a Compact Logix. I plan on using a Compact Logix 5380 with conversion Kit. The problem is that the analog input cards...
152
Hello, friends, I am trying to upgrade a system that uses an Onrom incremental encoder (E6B2-CWZ6C) connected to a Danfoss VFD (FC360), but now...
281
