tolerance and accuracy
Tolerance is the range within which a certain parameter must fall. For example, a hole must be drilled 35 mm in diameter, with a tolerance of +/- 1 mm. So the hole could be 34 mm to 36 mm and still be within specified tolerance.
Accuracy is usualy given in Per Cent. A hole of 35 mm with an accuracy of +/- 3% would mean that the hole could be 35 + (.03 x 35), or 35 - (.03 x 35), or 33.95 to 36.05 mm in diameter.
I agree on what Lancie says, but for me it would also mean:
I need a hole of 35 mm with a tolerance of 1 mm. So for any hole you make, it should be 34-36 mm
I have a drill, it is 35 mm and has an accuracy of +/- 3%, so a hole you make is expected to be within 33.95 - 36.05 mm (with a certain level of probability)
Pretty much the same as above but just another way to word it..
Tolerance is a given range of something that is exceptable...
Accuracy is a messurement of probable distribution of errors...
Well that what I was thought... o_O
Worth bearing in mind - Tolerance can also be stated as 35 mm +1, -0 .
This is useful for a hole in which a pivot pin is to be fiited . A 35mm pin with a tolerance of -1 , +0 will not be an interference fit. Using accuracy , 2 different sizes would be specifed to prevent seizing.
Paul
Specing Point IO to drive 3w 24vdc pneumatic solenoids. Switching frequency is approx every 3.5 sec. Math puts that at .125 amps. Debating...
2,667
I have an application where I am moving an anvil to a position and back. I am using a high speed servo valve to control the hydraulic fluid. My...
2,494
I am working on an installation that will require sensor cabling interconnecting sensors to PLC subject to outdoor temperatures. Will the ambient...
2,065
So I have a plc program where most of the outputs are based on a counter that goes from 0 to 1000. The counter speed is adjustable and is...
23
5,938
I have been working for a small turn key machine builder. We mostly do table top machine which do a few automated steps in assembling a product...
20
5,340
