Tools to Monitor Traffic on a DH-485 Network
sanger
Nov 2005
Toronto
172
We are trying to optimize the traffic on a congested DH-485 network. What tools are available for monitoring traffic on a DH-485 network? I would be happy with something that could display a simple count of messages/errors to and from each node on the network.
NetDecoder is the main battle tank of my communications troubleshooting toolkit. It is the only passive DH-485 analyzer that I know about, and FTE just rolled out two new USB/serial (one RS232, one RS422/485) interfaces.
If you do network troubleshooting extensively (it's a major part of my business), FTE is well worth the investment. It has solved problems for me that no other tool could.
The first thing I would do is make sure that every device in my network had a Channel Diagnostic file defined for the DH-485 network port. This is a great way to get the baseline information about how much traffic and how many errors are being seen by each device on the network. RSLinx should also give you some Station Diagnostic counter values for each device when you right-click in the RSWho view.
If you have the opportunity to get an oscilloscope onto the Data A and Data B signals of the network (relative to the isolated Common wire) that may help you get an idea of the signal quality.
First time I've used either the software or this unit. This is the setup I have right now. I have 20mA coming into AnalogIP1. Both the Main.PV...
47
I'm sure this question has been posted a thousand times on here but for me it was even funnier when I got to ask Rockwell / AB directly. My...
170
Dear members: Can anyone share old version of movitools 2.3 software for testing MDS60A sew drive?and how can I test motor without encoder in...
156
I'm just needed the iTools to configure the settings using RS485. Unless I read it wrong it is FREE for just that purpose. I went on Eurotherm...
607
Has anyone knowledge of CanOpen diagnosis tools-software. I found this of Helholz : https://www.helmholz-benelux.eu/product/can-bus-tester-2/ I...
977
