[Topic (read)] OPC server SImatic Net - Connection between PC Station and S7-1212C
naturephoenix
Jan 2015
Vienn
181
My problem is that I can not approach variables from OPC Scout 10. I can see Data blocks but not variables.
I'm using TIA portal v14, SImatic NET OPC V14.0 and I'm following this manual(pdf number 1):
https://support.industry.siemens.co...tation-to-an-s7-1200-with-opc-?dti=0&lc=en-WW
All examples in TIA portal I have found for TIA13 and I can not open it with TIA V14.
I have done following:
1. Disabled optimized block access
2. Enabled Permit access with PUT/GET comm....
3. I'm able to download program to PLC and to PC station.
4. I have configured Tags for OPC server
Inside OPC scout:
1. Inside SimaticNet -> S7-> I see only Localuser and DB1 but not any Tags. //
2. Inside SimaticNet -> SYM-> I see all Data Blocks but no any simbolic names(Tags)
Here I also attach picture which considers of 4 small images for better understanding. I can also put project.
1. Picture 1 shows that I can not see this part "S7_Connection_1"
2. Picture 2 shows that I can not see variables/tags as it is shows on picture(I can see all Data blocks but they are empty)
3. On picture 3 we can see 2 times s7_connection PLC to OPC and OPC to PLC. I'm missing this part which I put in black rectangle PLC to OPC. I dont know how to make it.
4. Picture 4 I am able to get.
Once I download all to PLC and go to Online there is an warning/error in diagnostic buffer where it says "Wrong partner -> No neighbour found" -> It means it can not see my IE ? I dont know why because downloading is possible and they are all in same local network.
I have wincc connectivitiy pack licence same as Simatic net S7 lean.
Any suggestions?
full symbolic access to the variables you can only get when you are using OPC-UA. In OPC-Scout browse "UA-Server" and then the OPC.SimaticNET.S7OPT server (key symbol = encrypted connection). Below Objects->SYM you should find your symbols.
If you cannot use OPC-UA because your client supportsOPC-DA only, then you need a special legacy configuration. In the PC-Station you have to configure the OPC-Server in version 8.2, then you can get access to "not-optimized" datablocks via symbol using OPC-DA.
Hello man, you have saved me. I have lost 3 days by just trying
and trying and killing myself to the head.
After this I'm feeling so excited. Thanks a lot
HI, im a student and never experience changing PLC battery. i have some questions in mind. 1. how will i know if the battery is low or it...
3,056
Hi all, I wanna Connect Glofa G7m LS PLC to WinCC Flex i have no Serial port in my laptop so i use USB to serial converter and...
2,509
I'm sorry to bother you all with this post as it is off topic but Im sure somebody here could help me. I do use PLC'S and have found this site...
6,236
GAS WAR - an idea that WILL work. This was originally sent by a retired Coca Cola executive. It came from one of his engineer buddies who retired...
89
22,229
This is the motor nameplate from one of the powder hoist motors on the USS Texas an older generation battle ship, built in 1911-1914 ish. The...
295
