Topworx Control Valve / Allen Bradley HART
jakeparsons03
Jun 2017
Indiana
78
Working on a site where they are using a DeltaV DCS system. They are using Topworx DVC6200 controllers on their modulating valves. These control both the I/P signal and positioner feedback. They are sending out the signal from their DeltaV system to control the position of the valve and using HART to receive the feedback signal instead of tieing into a second charm.
My question is, for allen bradley systems (5094-OF8IH) can I do the same thing? I don't see any reason why not. I figure that I just use a trex or something to put the feedback signal on the PV input and receive it back that way. Does anyone see anything wrong with that?
My goal of this is to possibly use this standard to do only 2-wire control of modulating valves instead of 4-wire, saving quite a bit of money in installation costs.
Rosemount seems to use the term "travel" instead of "position". "Travel" is one of the variables on the list of variables on page 14 of the manual.
https://www.emerson.com/documents/a...00-hw2-digital-valve-controller-en-123052.pdf
The 6200 manual shows the HART variables as being assignable (pg 91) in either of two categories: "with I/O" or "without I/O". One would hope that the local presence of a physical 4-20mA position retransmitter is not needed in order to read the travel position via HART, but I haven't used the 6200.
On the other end, presumably a HART enabled AO card can be configured to read a HART variable.
Sounds like it should work.
OK. I guess I'm getting old and forgetful. Maybe someone can wake my brain up. I have a TopWorx Limit Switch P/N DXP-E20GNEB that has 2 P&F...
991
Hi all, I am upgrading a couple of 2094-BC01-M01 servos with 2198-H015-ERS. The original code uses MSG instructions to control (release, engage...
70
Hey there guys, I'm relatively new to PLC programming. I had a few basic classes in college but since then I have mainly been on the instrument...
209
Hi, Is Control Expert V15.0 supposed to support multiple monitors? I'm running Control Expert V15.0 on my host Windows 11 PC, connected to two...
82
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
80
