Toshiba connection
Andy1983
Aug 2015
Northern England
22
Can anyone advise if a PC to PLC cable for a Toshiba EX20 would also work on a Toshiba EX250?
We have a cable marked up EX20: The cable is flat with RJ45 ends on it. the PC end goes into a connector which I assume has some electronics in it, running into a parallel connector.
Andy
No is the short answer. The longer answer is, it might work with a lot of re-wiring. 1st of all, the "parallel" connector you are referring to is not a "parallel" connector at all. It is a DB25 pin "serial" connector for the earlier serial port connnections used on computers at the time. 2nd, the RJ-45 connectors are not ethernet at all and cannot be used as such. 3rd, the programming port on an EX250 uses a special 8 pin connector that vaguely resembles a DB9 connector.
I would recommend building another interface from parts and leave the EX20 interface intact as they are also hard to obtain.
Having said all the above, if you need info or help building an interface cable for the EX250, let me know and I will be glad to help.
There is a long thread on the site here on how to build an interface for the EX100 Toshiba, which uses the same interface as the EX250 Toshiba.
Link:
http://www.plctalk.net/qanda/showthread.php?t=69165&highlight=ex100
Thanks for your help. I'll have a go at making one... I thought I'd check out if the EX20 one was compatible, but at least that questions been answered!
Thanks again
Andy
I just got an assignment to re-program a Toshiba T2-PU235N processor application. The programming package is the Toshibas T-PDS package. It was...
3,846
Hi, I have two Toshiba G3 Tosvert-130, one of them I can see monitoring mode, I can control with the LCD display, recently I changed the presets...
355
I inherited a system with the Micrologix 1500 talking to 8 VFDs using Modbus RTU protocol. One of the VFDs was replaced with a Toshiba VF AS1...
1,217
Another software thread! We have a Toshiba EX100 that's just been working away quietly in a panel for 20 years, never causing a problem to...
1,210
Hi, Any body had success to change parameters in between a Toshiba Inverter VF-S11 using a Red Lion any series (mine is K304), and MODBUS RTU...
1,163
