Toshiba Machine TS2100 External Select Program
RockyLeafs
Aug 2014
Southwestern Ontario
80
Morning,
At a customer site, working with a Toshiba TS2100/TH850A and I've created a new program to add in a new part type on an existing machine. My new program is working fine, but the customer wants it to automatically select the program based on which product type they are running. (Which I agree with..)
The original OEM did not account for program changing when they built the machine back in 2009.
I did find the manual for the TS2100, and I've found both where the Toshiba select which program to run (EXTRNSEL.SYS) and the user parameter [U07] to select which inputs and length for selecting the program.
I did try to use DIN 19 - 20 to select the program, then tried DIN 13 & 14, both with no luck. When the robot starts up, the controller gives me an 'External SELECT" error. I did read in the manual that for inputs it would require DIN 1 - 16, so that may explain why 19 - 20 didn't work, but I though 13-14 would.
Any help would be appreciated. DIN 13 and 14 are not used in either program. They are referenced in a comment to describe what each input does but they aren't used anywhere.
Hi, I have two Toshiba G3 Tosvert-130, one of them I can see monitoring mode, I can control with the LCD display, recently I changed the presets...
345
I inherited a system with the Micrologix 1500 talking to 8 VFDs using Modbus RTU protocol. One of the VFDs was replaced with a Toshiba VF AS1...
1,204
Another software thread! We have a Toshiba EX100 that's just been working away quietly in a panel for 20 years, never causing a problem to...
1,203
Hi, Any body had success to change parameters in between a Toshiba Inverter VF-S11 using a Red Lion any series (mine is K304), and MODBUS RTU...
1,153
So far, the Toshiba drives seem to be the best out there. I wish their software was a little better though.
2,029
