Toshiba Prosec M40 - sofware + hardwarekey + Cable
Feb 2006
Enschede
Hello,
I have some troubles to communicate with my old Toshiba PLC.
Where can I find the software to program my M40 PLC & do I need an hardwarekey to do this.
What kind of cable do I have to use and where can I buy this.
I already have an software version downloaded from Toshiba , but this one is asking for an hardware key, I don't know where I can buy this key ???
Please give me some advice,
Best Regards
Bart Jan mellink
Toshiba communications
Hi Jan, i assume you are using expdd which requires a key attached to the printer port to do anything usefull. Expdt is another option that does not need a key but does not support offline editing. Regarding the comms cable, the rs 232 data is converted in a black box to a current loop format. I suspect a max 232 chip or similar but have not found circuits to suit. A search for such devices will turn a few up from automation comms suppliers. Good luck, Brenton.
Hi, yes you are understand my problem
I don't have an hardware key but i have the communication cable wo provides expdt programming online.
Where can I find the Expdt software ??
Maybe you have an idea
Thanx
M20
Bart, have you contacted a local Toshiba office for support, they may have a copy available. This and other obsolete software was available for download from toshi but seems to have disappeared.
Brenton.
yes I have, but Toshiba doesn't support the M40 any more so I can 't find the program any where.
Do you haven an suggestion where I can find he software ?? I really need it to adjust te program,
Bart Jan
We have a machine with a Toshiba Prosec T2 PLC with a PU215N CPU. The PLC's BAT LED is on. Luckily, at this stage, the Run LED is also on...
2,177
Anyone know where I can get a programming lead for a Toshiba PLC A Prosec T1 MDR40S I actually have one on order from ebay coming from China but...
2,399
Greetings, I need list of modbus mappings for the following PLC :- Model:Toshiba Prosec T2, Processor:PU234E, Modbus Module:ML11(A) Thanks
4,020
Where can I buy Toshiba TOSMATIC PROSEC Series PC50 Programmable Controller modules, either new or re-conditioned? Ken
4,678
Hi, I have two Toshiba G3 Tosvert-130, one of them I can see monitoring mode, I can control with the LCD display, recently I changed the presets...
347
