toshiba T16S index addressing
interdog
Mar 2016
antigua
I am an amatuer but used to be professional real time embedded guy.
PLC and micro works differently i see.
I finally need to use indexing as a way to indirectly address registers. I have read everything and notice when an index modified register is written an I, J or K appears above the value,to say the index is in play. What I cant find is how you enter your register so that the index is applied and the I,J,K appears in your program? Ive read the book till Im blue in the face.
Also the FOR NEXT looks like it can only use a constant for n, number of iterations whereas I need my subroutine to execute the number of loops specified by the CALLER.
Also JMP cant jump backwards. How to I create a FOR NEXT loop with program specified n?? Thanks - pardon the ignorance
Hi, I have two Toshiba G3 Tosvert-130, one of them I can see monitoring mode, I can control with the LCD display, recently I changed the presets...
354
I inherited a system with the Micrologix 1500 talking to 8 VFDs using Modbus RTU protocol. One of the VFDs was replaced with a Toshiba VF AS1...
1,216
Another software thread! We have a Toshiba EX100 that's just been working away quietly in a panel for 20 years, never causing a problem to...
1,209
Hi, Any body had success to change parameters in between a Toshiba Inverter VF-S11 using a Red Lion any series (mine is K304), and MODBUS RTU...
1,162
So far, the Toshiba drives seem to be the best out there. I wish their software was a little better though.
2,049
