Toshiba Tactile 20 Operator Interface
martinAPD
Jan 2006
Scotland
29
Good morning everyone.
I was hoping someone will be able to help me on this one. I have a customer that has a Toshiba Tactile 20 Operator Interface which is connected to a Toshiba T1-28 PLC. The customer is planning on doing some major maintenace to thier system which will require the PLC to be powered down.
We have sourced a copy of the PLC Programming Software and a PLC Comms cable to allow us to backup the PLC Code. However we cant find any information on the HMI.
Does anyone know if the HMI is programmed via the PLC, in a similar way to some Siemens HMI's? Or is there a stand alone software package to do this? Is so does anyone know what this software is called?
Thanks for all the help.
Cheers
Hi, I have two Toshiba G3 Tosvert-130, one of them I can see monitoring mode, I can control with the LCD display, recently I changed the presets...
354
I inherited a system with the Micrologix 1500 talking to 8 VFDs using Modbus RTU protocol. One of the VFDs was replaced with a Toshiba VF AS1...
1,216
Another software thread! We have a Toshiba EX100 that's just been working away quietly in a panel for 20 years, never causing a problem to...
1,209
Hi, Any body had success to change parameters in between a Toshiba Inverter VF-S11 using a Red Lion any series (mine is K304), and MODBUS RTU...
1,162
So far, the Toshiba drives seem to be the best out there. I wish their software was a little better though.
2,049
