Toshiba TS3000 with Ethernet/IP to Rockwell PLC
RockyLeafs
Aug 2014
Southwestern Ontario
80
Has anyone had any luck getting a Rockwell PLC (Compactlogix with Ethernet/IP) to communicate to a Toshiba TS3000 with Ethernet/IP.
I imported the EDS file, the IO says its ok (running) but not seeing any input/output change states between the PLC and robot controller.
I followed all the steps in the Fieldbus manual but no luck yet...
Hi, I have two Toshiba G3 Tosvert-130, one of them I can see monitoring mode, I can control with the LCD display, recently I changed the presets...
347
I inherited a system with the Micrologix 1500 talking to 8 VFDs using Modbus RTU protocol. One of the VFDs was replaced with a Toshiba VF AS1...
1,205
Another software thread! We have a Toshiba EX100 that's just been working away quietly in a panel for 20 years, never causing a problem to...
1,205
Hi, Any body had success to change parameters in between a Toshiba Inverter VF-S11 using a Red Lion any series (mine is K304), and MODBUS RTU...
1,155
So far, the Toshiba drives seem to be the best out there. I wish their software was a little better though.
2,033
