Toshiba VF-S11
jpoyatos
Oct 2009
Forney
Any body had success to change parameters in between a Toshiba Inverter VF-S11 using a Red Lion any series (mine is K304), and MODBUS RTU setup on HMI for communications, serial RS485 two wires and right card on the VF-S11.
If some body can help will be excellent.
Thank you guys for your help and time.
Jose
Have you tried Modbus communication with some Modbus simulator from PC?
When something is not functioning with Modbus, I always try equipment with PC, to eliminate bad setup.
Greetings, I need toshiba AS11 ASCII/BASIC module information about DIP switch setting, Can you help me? Best Regards,
1,413
Hi, I have two Toshiba G3 Tosvert-130, one of them I can see monitoring mode, I can control with the LCD display, recently I changed the presets...
357
I inherited a system with the Micrologix 1500 talking to 8 VFDs using Modbus RTU protocol. One of the VFDs was replaced with a Toshiba VF AS1...
1,220
Another software thread! We have a Toshiba EX100 that's just been working away quietly in a panel for 20 years, never causing a problem to...
1,212
So far, the Toshiba drives seem to be the best out there. I wish their software was a little better though.
2,054
