totalizer block for micrologix 1400
walterharper
Jul 2012
mobile, al
Has anyone out there created or knows where to find a 4-20 in totalizer block for Micrologix 500. I am needing to add a couple totalizers to an existing system and find no block supplied by AB.
Thanks,
Walt
I am trying to setup the TOT function block so that I bring in GPM and want to output MGD. I cannot seem to figure out the correct gain in the...
2,720
Greetings, this is the first FB programming I've done. It is running a totalizer from a flow transmitter. the routine is being jumped to...
25
5,204
Hey GE guys, wondering if any of you had any experience with getting the TOTALIZER instruction working in Proficy Machine Edition. Seems...
3,772
I hope to use the Modicon Concept TOTALIZER block to totalize a flow rate. I have set up a test in the simulator to familiarize myself with the...
2,121
In a distillation column application a control valve opens to remove distillate product and closes to return reflux. Cycle_Period timer is set for...
11,655
