Touch Pad Security
RSVIEWRULZ
May 2003
Far Away
47
I have been tasked to come up with a way to prevent unwanted machine usage in a maintenance facility
They requested that a small touch pad be used with a changeable security code. The operator knowing the code will have to input the code to be able to start the machine. also requested was a configurable auto log out function. I am not going to let this be a determining factor...
All the unit needs is be able to operate a relay or two.
If anyone has seen a small device like this or can point me in some directions, I would appriciate it.
thanks
:D
It might be a bit much for the application, but the Mitsi E series HMI's have different security levels (with different codes) for operators/maintenance/supervisors. They have a function that will auto log out after a certain time.
Combine that with the smallest PLC you can find, and hey presto! you have a solution. Good or not is your decision...
Security Pad
You could take a look at the Horner line of OUI's. They have a keypad, screen and small PLC built in.
Take a look at Unitronics . I have been working with their V280 HMI/PLC unit and am very impressed with its capability. I know they have some small units that should suit your description.
I have programmed in password protection for getting to certain screens on this unit with no problem. It seems to me that upon entering the password protected screen, you could start a timer that would monitor whether any buttons were pressed or if the machine is running. If there is no action and the machine is idle the timer would time out and auto-log out. Each time a button is pressed, the timer would reset. These units are pretty inexpensive, too.
My .02
Steve
Hey folks, We have a PView+ 700 here that I've gotten set up. I've been told that it's possible to disable the touch screen on these but I can't...
2,224
I am trying to replace the touch pad portion (part# p23touch) of a ctc p21-012ar hmi and all is going well except the ribbion cable on the new one...
1,477
Working with Wonderware InTouch version 10. Is it possible to change the font size in the native pop up numeric keypad and the pop up keyboard? I...
3,884
First time poster. I'm working on getting a Panelview 600 2711-B6C5 to communicate to a 1768-L43 controller through the RS-232 port using a...
3,257
I am using Beijer T100 Exter touch screen with a keypad. The thing is screen is polling key pad all the time, if keypad detects that its not being...
1,934
