Touch problems with Siemens TP170B
orense
Apr 2006
Norway
196
Hello,
I have a service engineer on site, and he is struggling with a touch panel.
The touch pointer is way off where he is pressing the touch screen.
So much that he is not able to go into control panel and calibrate it.
Does anybody know any other method to fix this, if there is any dip switch setting or anything that resets the panel completely?
Or is it scrap?
Thanks for suggestions!
Andreas
Does the TP170B have an USB port ?
If it does, you can use that to access the windows control panel and the touch calibration.
I think also that the touch calibration can be started by a system function. So you could assign that system function to a PLC tag on event change value, and thereby be able to activate it from the PLC.
You would have to setup that in a modified project and download it to the panel.
Thanks,
No the panel does not have any usb port. Only 9 pins ports.
My colleague is trying to factory reset it, if it does not work, then I will try to load the system function you mention.
Brg
Andreas
Hi
I would ask him to try and work out the touch 'offset' so he could do the calibration by touching the screen. I realise it is not easy
Cheers
I currently have 4 siemens mp277 10 inch touch screens I deal with. Lately 2 of them have been giving erratic touch screen results. To specify...
1,790
Hello! I have a question regarding the HMI in InTouch, almost a month ago I made an HMI and I have not used it again, now I need to make changes...
2,048
Hello, M using intouch 11.0 with AB, M new to intouch. I have read some pdf regarding uploading downloading editing of in touch application...
1,567
I am new to this line of work so please excuse me if this is extremely simple. I have also Searched the forums and web for answeres and am getting...
1,291
Hi All, i have an Client with a old Intouch V10.0 installation, now i am trying to setup a new development station but the active x menu bar used...
1,105
