TP170A Messages
JOLTRON
Aug 2006
MI
692
Hello, I have a TP170A connected to a Siemens CPU226. The TP is able to store 100 messages as long as memory permits. My memory is about half full on the TP so I do not belie this is the problem. Nothing is over writing my bit being sent. It works up to message 52. V107.4 would be message 53 and it is on when I go into the status screen but the message does not pop up on the screen. My Event_Msg tag on the TP is an array of 5 words starting at V100.0 so I shouldn't be out of the range that it's inspecting. Any Ideas???
Thanks,
-Joel
Nevermind this one guys. Switched up from ProTool to Wincc and didn't notice that Wincc has a number for each alarm but that is not the "Bit" to be set to set it off. Far to the right side there is a Trigger bit.
Thanks anyways,
-Joel
Hi All Please could you all help me to know how event messages work in TP170A HMI and my s/w is ProTool V6.0 SP2. How does the message come...
1,994
Hi All, Have a small application problem with a Siemens TP170A, I am driving event messages via a DB however it is possible that I can have up to...
6,356
Hi guys, I have Siemens TP170A with touch non-operative. I have replacement but Touch Screen do not work (cannot set Transfer Mode to make a...
2,333
I have a siemens tp170a hmi and tried just for fun, to use modicon modbus driver settings and communicate with a regin roomcontroler. I use the...
2,119
I am trying to extract an existing program from a Siemens TP170A HMI, using ProTool CS. Thus far, I have been unable to establish communication...
3,437
