TP270 - System time settings
adfox
Jun 2006
Poland
334
Hi, is there any way of changing Panel's System time from protool runtime, without exiting it ? Date output field has option TAG/System time but input has only a tag to select.
How can I set system time from a tag ?
Or how to open directly system time properties from windows control panel ?
Protool has function Open control panel, but i need to open just date and time settings.
Thanks in advance,
adam
Hello adfox.
Insert an object of type "Date/Time". This presents an input/output field that sets the system time directly without going via a tag.
edit: If you want to, you can indeed use a tag, but it is not a requirement.
Geez, Thanks, i must be blind today :/
I just noticed checkbox "Allow Edit" on the Date and time object.
Thanks again.
Not to hijack this thread, but is there any simple way to synchronize PLC time with HMI time (TP270 to 317 processor)? I'd like to able to allow the operator to set the time in the HMI as detailed above and have the new time applied to the PLC to use for time-stamping. From some preliminary reading it looks like I might have to use an area pointer but I would be interested to know if anyone has a better suggestion?
Hi Binaural
Indeed it is pretty easy to make time synchronizing between panel and PLC. Because, I don't know how to explain it in english, but here is one example how i make it (in principal).
Pete
Hi guys, I have a trainer with a Siemens S7-315 Processor and a TP270 HMI, using an MPI adapter to connect. I have gone over every setting I can...
1,749
Dear all, We are using a TP270 6" in our machine we dont have the original back up of the touch panel having two problems. 1) m trying to upload...
1,816
Hello everybody! I have a question about PLC CTI 2500 model C200. We have device with this controler but it hasn't a operating panel. I want...
1,837
Hello, I am using step7 v5.5 and wincc flex 2008. I have created my PLC program have it working, but I am having trouble with my...
10,092
Hello to all and thanks for your interesting website I was trying to get data from Siemens TP270 panel using WinCC flexible2008 When Downloading...
3,321
